Skip to main content
Get help with call routing for Admins | BT Business
not-authored-help-and-support
Your guide to Microsoft Teams Operator Connect
I need...
What do you need help with?
Get help
To complete the tasks in this article, you’ll need to be an administrator. Learn more about Teams administrator permissions.
Suggested help
Calls are not routing to the correct user
Solution: Check that the correct Operator Connect phone number is assigned to the user.
  1. Go to Teams Admin Centre.
  2. Select Users > Manage users.
  3. Choose the user.
  4. Under Account, verify the Phone number field.
  5. Reassign the correct number if needed, or contact our support team if the number is missing.
Calls are routing to the wrong Auto Attendant or Call Queue
Solution: Make sure the phone number is assigned to the correct resource account.
  2. Select Voice > Phone numbers.
  3. Search for the number.
  4. Check the Assigned to field.
  5. Select Edit and assign it to the correct Auto Attendant or Call Queue.
Calls are not reaching the Call Queue
Solution: Review the Call Queue configuration to ensure agents and routing settings are correct.
  2. Select Voice, then Call queues.
  3. Choose the Call Queue.
  4. Check the Agents list.
  5. Review Presence-based routing, Overflow, and Timeout settings.
Calls are not routing to voicemail
Solution: Confirm voicemail is enabled and call forwarding rules are not overriding voicemail.
  3. Choose the user.
  4. Under Policies, check the Voicemail policy.
  5. Under Voice, review Call answering rules.
Calls are routing to the wrong device
Solution: Check the user’s call forwarding and simultaneous ring settings.
  2. Select Users, then Manage users.
  3. Choose the user.
  4. Under Voice, review Call forwarding settings.
  5. Ask the user to check their Teams client if they are signed in on multiple devices.
Calls fail when routing to a resource account
Solution: Ensure the resource account has the correct licence and phone number assigned.
  1. Go to Microsoft 365 Admin Centre.
  2. Select Users, then Active users.
  3. Search for the resource account.
  4. Check Licences and apps for Phone System – Virtual User.
  5. Go to Teams Admin Centre, then Voice, then Phone numbers and confirm the number assignment.
Calls are not routing after a number port
Solution: Verify the port has completed and the number is correctly assigned in Teams.
2. Select Voice, then Phone numbers.
4. Check the Status and Assigned to fields.
5. If the number is unassigned or unavailable, contact our support team.
Calls are routing to the wrong location or site
Solution: Check the user’s usage location and the emergency address assigned to the number.
Usage location:
  3. Choose the user.
  4. Under Account, verify Usage location.
Emergency address:
  3. Choose the number.
  4. Review the Emergency location field.
  5. If the address is locked, contact our support team.
Did this help?
Additional support
