Skip to main content
Viewing call history and voicemail in Operator Connect | BT Business
not-authored-help-and-support
Quickly review your recent calls and voicemail. Follow the steps below to view your history, manage entries, and open voicemail messages.
  1. Open Microsoft Teams.
  2. Select Calls from the left-hand menu.
  3. Select History.
Removing a call from your history
  2. Select Calls, then History.
  3. Hover over the call you want to remove.
  4. Select More actions, then Remove from view.
Accessing voicemail
  2. Select Calls.
  3. Select History, then Voicemail.
  4. Select a message to view details.
Did this help?
Additional support
