Skip to main content
My phone line is not working. What can I do? | BT Business
not-authored-help-and-support
There are a couple of things to check if you think it's your phone line not working.
Your broadband might still be working even if your phone line isn't. If it's your Cloud Voice Express service you're having problems with, head over to the Cloud Voice Express troubleshooting page.
No dial tone, static or noise on the line, or you can't hear anything
Your phone doesn't ring or rings but cuts off
I've got a dial tone, but can't make outgoing calls
Testing your phone equipment
Testing your wiring
Report a phone line fault
Did this help?
Additional support
