Skip to main content
How to use BT broadband speed tests | BT Business
not-authored-help-and-support
We’ve got different BT broadband speed tests for our different hubs. So first we need to know which hub you’ve got. Find out your hub.
Test speed for BT Business Smart Hub 2 and Smart Hub
BT broadband speed test on app
BT broadband speed test in My Account
Test broadband speed for other hubs
BT broadband speed test using a different checker
Support after your BT broadband speed test
Is your broadband speed slower than expected? Try moving your hub to get a faster connection. Find out how to fix slow broadband and wi-fi speeds.
If you’ve tried our speed tips and your broadband’s still slower than expected, report a fault online and we’ll put things right for you.
What can affect my broadband speed?
Did this help?
Additional support
