Skip to main content
How to access the Smart Hub Manager
not-authored-help-and-support
The Hub Manager is where you can change or view your Hub's settings.
  • Open a web browser
  • Type 192.168.1.254 into the address bar (where you normally type the internet address; there's no need for www or http, just type the number directly into the address bar).
  • Press 'Enter'.
Advanced settings
You'll need the 'Admin Password for Hub Manager' to make changes to the advanced settings. You'll find it on the back of your Hub. Note: it is not the same as the wireless password.
Did this help?
Additional support
