Getting started with BT One Phone couldn't be easier. Just put your BT One Phone SIM card into your phone and switch it on. You're ready to make and receive calls.
Your SIM won’t have an active SIM PIN when you first receive it. If you want to set one up to protect your SIM from misuse, your device user guide will tell you how - it'll only take a minute. You'll need to know the default PIN, which is 0000. You can change it to something more memorable by following the instructions. Keep a record of your PIN in a safe place.
To move contacts from another phone to your BT One Phone you should consult your device user guide.
BT One Phone quick start guide (PDF, 525KB)
Accessing the BT One Phone Portal
The BT One Phone Portal is an online tool that makes it easy to manage your personal settings and preferences, helping you work smart on the move. To access the portal you'll need to register and create a password:
- Go to www.bt.com/btonephoneportal and click on the Register button.
- Enter your mobile number with 44 at the beginning, no zero and no spaces, for example 44712345678).
- Click Next.
- Enter your mobile number again as the username that you'll use to log in to the portal.
- Choose whether you want your password sent to you by email or text.
- Click Next.
You're now registered. A password will be sent to you by text message or email.
To access the BT One Phone portal once you're registered, go to www.bt.com/btonephoneportal and enter your username and password. You'll be prompted to change the initial password.
Or if you've installed the alert client, right click on the alert client icon (in your tool tray at the bottom right hand corner of your screen) and select Open VPBX to go straight to your own user area of the BT One Phone portal.
BT One Phone training videos
We want to make sure you make the most of your BT One Phone solution. The training videos below will help get you started and introduce you to the many features and functions that BT One Phone has to offer - features designed around the way you work, with the aim of making your life easier.
How to register and find help and support on the BT One Phone portal
How to use our Help and Support pages
Getting started with the BT One Phone portal
How to use the call handling features
How to use the dial-in service menu
How to set your availability and presence settings
Personalise and listen to your voicemail
To set up your voicemail name and a personal greeting, dial 8888 from your BT One Phone and then follow the instructions.
Once your voicemail has been set up, to access your messages (most recent first) you can:
- dial 8888 from your BT One Phone; or
- dial 8880 from your BT One Phone for the dial-in service menu and choose option 2; or
- on the BT One Phone mobile app, select My Status in the main menu and then tap Call voicemail.
You can set up or access voicemail from another phone by calling 07953 223888 or +44 7953 223888 from any phone while you're abroad.
You'll need to make sure you've set up a VPBX PIN code which you can find out how to do below, otherwise you won't be able to access your messages.
Finding your personal BT One Phone numbers
You'll find your personal numbers (as listed below) in your welcome pack letter.
There’s an overview of all your numbers on the BT One Phone portal in the Personal info tab under My Subscriptions or in your Call Settings menu bar in the My Status section. On the BT One Phone Mobile app, select My Status in the main menu and you'll see your number listed at the bottom.
As a BT One Phone user, you get the following phone numbers. A call to any of these numbers will reach you on your BT One Phone device:
Mobile phone number (e.g. 07123 456 789)
Landline number (optional, e.g. 01234 567 890)
Extension number (e.g. 7890) - you can use extension numbers instead of the full mobile or landline number to make or receive calls from colleagues wherever you are in the UK.
You can have up to 5 additional numbers if needed which will reach you on your BT One Phone.
Setting up a BT One Phone VPBX PIN code to call from another phone or when abroad
You'll need a PIN (called the VPBX PIN code) if you want to access BT One Phone from another phone in the UK and when using any phone to call from abroad. Set it up as soon as you can so you don't forget.
Here's how to set up or change your VPBX PIN code:
- Dial 8880 from your BT One Phone in the UK and choose option 3; or
- Go to the BT One Phone portal in the Personal info tab under Username and password.
BT One Phone dial-in service
The dial-in service menu lets you set-up and manage your features and settings from your BT One Phone. So, if you're ever in a situation where you can’t access the BT One Phone portal, the good news is that you can do everything on your phone using the dial-in service menu.
To access the dial-in service menu from your BT One Phone, just dial 8880, and the audio instructions will explain your options:
- Change your presence status.
- Listen to your voicemail.
- Set up your voicemail or your voicemail PIN code.
- Set up a ‘follow-me’ number.
- Manage your groups.
- Group manager admin functions.
- Create a BT Meet Me conference PIN.
- Listen to group voicemail.
Press * at any time to get back to the main menu.
You can access the dial-in service menu from another phone by calling 07953 223880 or +44 7953 223880 from any phone while you're abroad.
You'll need to make sure you've set up a VPBX PIN code, which you can find out how to do above.
