Skip to main content
Call Recording on Cloud Voice | BT Business
not-authored-help-and-support
With Call Recording on BT Cloud Voice, you can record calls and store them securely in the cloud.
Both users and administrators can:
  • Access the Call Recording dashboard for a summary of recorded calls and data such as Calls By Category, Frequent Callers, Call By Location, Agent Summary, and more
  • Monitor and listen in to calls in near real time
  • Add a reference number to the recording
  • Add notes and comments – to help with staff coaching, for example
  • Choose from our options how long you want to keep the recordings before they're deleted automatically
  • Download and archive calls any time before they're deleted
To help you get the most from Call Recording on BT Cloud Voice, take a look at our user guides:
BT Cloud Voice Call Recording user guide (PDF, 1.5MB)
BT Cloud Voice Archive Scheduler user guide (PDF, 1MB)
Did this help?
Additional support
