Skip to main content
Troubleshooting problems with Guest Wi-Fi | BT Business
not-authored-help-and-support
When you’ve set up and switched on Guest Wi-Fi your guests can use the public network securely and for free. If you’re experiencing any issues they can usually be resolved easily.
Guests can't connect to Guest Wi-Fi
Turning on Guest Wi-Fi has frozen Hub Manager
Guests can see a page not available error
A guest was online but then lost connection
Guest Wi-Fi appears as an unsecured network
Guest Wi-Fi is running slowly for my guests
To find out more about Guest Wi-Fi have a look at our guide to Guest Wi-Fi.
Did this help?
Additional support
