You’ll need to enable the Bridging feature.
From the Hub Manager home page, go to -
- Advanced Settings
- Broadband
- Routing
- Enable Bridging
When you enable Bridge mode, your hub light will turn orange, your Hub will act as a modem only. This will disable any router features, such as NAT, DHCP, DNS and LTE mobile connections.
