Skip to main content
Using Smart Hub 2 as a modem only
not-authored-help-and-support
You'll need to enable the Bridging feature.
From the Hub Manager home page, go to -
  • Advanced Settings
  • Routing
  • Enable Bridging
When you enable Bridge mode, your hub light will turn orange, your Hub will act as a modem only. This will disable any router features, such as NAT, DHCP, DNS and LTE mobile connections.
Did this help?
Additional support
