You can set up your MiCloud voicemail account to forward your messages to email. This means you're no longer tied to your desk – if you can access your email, you can access your voicemail.
You can set up this service in your Customer Portal using the following simple steps:
- Open the User Portal, using the URL included in your welcome email
- Where prompted, enter your username and password and hit Login
- Once the homepage loads, select the My Profile tab
- Select the My profile tab
- On the My Profile page, choose the Voicemail tab
- For simple forwarding of voicemail to email, select Enable Forwarding to Email
- To synchronize messages between voicemail and email via unified messaging, select Embedded UM Enabled
- Hit Save
Please note: your messages will be sent to the email address we used when we set you up on the system.
