Call Pick-up allows an extension to answer another extension's call as long as both extensions are programmed in the same Call Pick-up Group.
These calls can be:
- internal calls
- external calls
- DDI calls
- CLI routed calls.
Using a V featurephone to answer a call using the Call Pick-up
From the Idle phone menu, select Call Pick-Up on the Display for any types of calls or select External Call Pick-Up.
From a standard telephone:
- To answer any type of call, dial the feature code 727
- To answer incoming calls only, dial the feature code 726
