Skip to main content
Connecting to IP Office | BT Business
not-authored-help-and-support
It’s quick and easy to connect to IP Office. You’ll need access to IP Office Manager to do this. Download IP Office Manager.
  1. Click on Start and find the IP Office folder.
  2. Double click on the IP Office Manager.
  3. The Manager will locate the IP Office system if you are on the same network.
  4. Tick the box next to your IP Office IP address and click OK.
  5. Enter the username and password and select OK.
Did this help?
Additional support
