Skip to main content
Help with AI Receptionist (AIR) and AI Receptionist Everywhere (AIRE) | BT Business
not-authored-help-and-support
Help with AI Receptionist and AI Receptionist Everywhere
Both AI Receptionist (AIR) and AI Receptionist Everywhere (AIRE) can answer calls, respond to common questions and route callers to the right person.
  • AI Receptionist (AIR) is for customers who have BT Cloud Work.
  • AI Receptionist Everywhere (AIRE) is a standalone service, so you don't need to purchase BT Cloud Work to use it.
Manage AI Receptionist and AI Receptionist Everywhere
You manage AI Receptionist and AI Receptionist Everywhere through the BT Cloud Work portal.
If you're an Admin, you'll get a welcome email when your service is set up. The email includes a unique link for you to set up your password and PIN.
Log in to the BT Cloud Work portal
You can find out more about using the BT Cloud Work portal, including how to manage users, settings and your account.
Get started
Choose the product you have from the list below to find the right setup instructions.
Set up AI Receptionist
If you have AI Receptionist (AIR) with BT Cloud Work, follow the setup guide to get started.
Set up your AI Receptionist
Set up AI Receptionist Everywhere
If you have AI Receptionist Everywhere (AIRE), follow the setup guide to get started.
Set up your AI Receptionist Everywhere
Get more help
Want to learn more about setting up and managing your AI Receptionist or AI Receptionist Everywhere service?
Find your product below and check out our step-by-step guides:
Get more help with AI Receptionist
Learn how to:
Get more help with AI Receptionist Everywhere
If you’ve got the Everywhere tool, learn how to:
You can get further help and support on our BT Cloud Work site.
Did this help?
Additional support
