Skip to main content
Withhold Number and find out who called you using 141, 1470 and 1471 | BT Business
not-authored-help-and-support
Withhold your number and find out who’s called using 141, 1470 and 1471
You can choose to hide caller ID (withhold your number) by using 141, show caller ID by using 1470 when you're making outgoing calls or find out who’s called you last using 1471.
141 – Withhold your number
141 – Withholding your number on a Featureline
1470 – Showing your number or disable 1470 on your line
1471 – Find out who’s called you
1475 – Erasing the number stored under 1471 using 1475
Troubleshooting
Is it a malicious or nuisance call if it's withheld?
Why can I hear my own phone number when I dial 1471?
Did this help?
Additional support
