Call diversion is an added feature on our phone lines — to buy it head to our sales pages.
Call diversion codes
Whether you’re using call diversion to forward calls from your landline to a mobile or to another landline there are specific codes you’ll need to enter.
| Action | Code |
| Divert all calls | 21 |
| Divert calls not answered within 15 seconds | 61 |
| Divert calls if phone engaged | 67 |
How to use call diversion with your handset
- Press * followed by the divert code
- Press * followed by the phone number to divert to
- Press #
You’ll hear an intermittent dial tone when it’s on – this doesn’t affect outgoing calls.
If you’ve got Call Minder, the intermittent dial tone means you’ve got a new message, not that a divert has been set.
How to cancel call diversion using your handset
- Press # followed by the divert code
- Press #
Checking call divert is on using your handset
- Press * then #
- Type the divert code followed by #
Costs for using call diversion
The diverted part of your call is charged at our standard dialling rates. Read on to find pricing information for all calling features
