Skip to main content
Installing Business Antivirus Protection | BT Business
not-authored-help-and-support
How to install Business Antivirus Protection
Help with installing Business Antivirus Protection, plus the system requirements, and how to use Business Antivirus Protection.
Business Antivirus Protection for administrators
As an administrator, you can install Business Antivirus Protection to your own device, plus email your employees so they can install it on their device.
Install Business Antivirus Protection on your device
  1. Use your BT username to log in or sign up to My Account
  2. Go to Manage your services to find Business Antivirus Protection
  3. Select Manage settings and you’ll go to the McAfee My Account portal
  4. In the McAfee My Account portal, select the device type that you want to protect
  5. Select Download and accept the terms and conditions
  6. Note the serial number or activation code
  7. Open the McAfee software download file and follow the instructions to download
Email Business Antivirus Protection to your employees
  5. Select Send link
  6. Enter the email address of the employee you want to install Business Antivirus Protection
  7. Select Email me
  8. Repeat steps 6 and 7 until you’ve emailed all the employees you need
Business Antivirus Protection for employees
First, your administrator needs to arrange for you to install Business Antivirus Protection. When you receive your installation link by email, you can protect your devices with these steps.
Install Business Antivirus Protection on Mac or PC
  1. Open the Welcome email from McAfee sent by your administrator
  2. Choose your device type and select Protect me
  3. Select Download and accept the licence agreement
  4. Note your activation code – you’ll need to enter it during installation
  5. Follow the on-screen instructions to install Business Antivirus Protection
Install Business Antivirus Protection on mobile
  2. Under Mobile Protection, select Protect me
  3. Note the serial number or activation code in case you need it during installation
  4. Select Download to automatically go to the Apple App Store or Google Play
  5. Follow the steps to install and set up the app
  6. Go through the welcome screens until you reach the McAfee sign-in screen showing your email
  7. Enter your password (or follow the steps to create a new password)
  8. When you enter your password, you’ll activate the app on your device
Help with Business Antivirus Protection
System requirements for Business Antivirus Protection
You’ll need to be connected to the internet to install Business Antivirus Protection, and have these system requirements:
Operating system
  • Microsoft Windows 11, 10, 8.1 fully patched (32-bit and 64-bit)
  • Build 4.11.1 or higher: macOS 10.15 and above
  • Build 4.9.1: macOS 10.12 - 10.14
  • Google Android smartphones and tablets 7 or higher
  • Apple iOS 13 or later
Windows Enterprise is not supported.
Supported browsers
  • Firefox
  • Google Chrome
  • Safari (macOS and iOS only)
  • Microsoft Edge (Chromium-based)
How to use Business Antivirus Protection
When you’ve installed Business Antivirus Protection you can access it using the shield icon. Here’s where you’ll find it:
  • PC: Task bar
  • Mac: Dashboard
  • Tablet or mobile: Home screen
Business Antivirus Protection scan speeds can vary between devices. Many factors can affect scan speeds, such as operating system version, if operating systems is up-to-date, and performance of the device.
Did this help?
Additional support
