Your BT Business Broadband package comes with BT Web Threat Protect. This warns you if you're about to visit a website that contains content that's harmful or malicious. One of the ways we're helping you to keep your business safe from viruses, scams, and phishing attacks.
When Web Threat Protect is activated, any device you're using with your BT Business Broadband connection is protected online. It even works abroad when you use your BT username to log in to BT Wi-Fi.
Activate Web Threat Protect in My Account.
Does Web Threat Protect replace my BT Business Antivirus Protection?
No, it doesn’t replace your BT Business Antivirus Protection or any other Endpoint protection solution. This is because Web Threat Protect works at the network level and other endpoint protection solutions work at device-level — use them together for the enhanced protection.
Do I need to set up Web Threat Protect on all my devices?
No, you only need to turn it once at a network level. When it's been activated it's applied to any device which uses your BT Business Broadband connection or BT Wi-Fi that you access with your BT username.
If you're using a non-BT router you may need to change its settings.
Is my device protected when I'm outside?
You're protected by Web Threat Protect if you're connected to any UK BT Wi-Fi hotspot with your BT username.
What if Web Threat Protect tells me a site isn't safe, but I think it is?
Please email saferbrowsing@bt.com if you think Web Threat Protect has made a mistake about a safe site and we'll investigate and let you know whether the site seems safe. We can't discuss individual decisions in detail though.
Why am I seeing a blank screen when I try to visit a website?
This happens if the URL of the site you're trying to visit starts with https. If this is the case, Web Threat Protect stops you visiting the page and you see a blank page instead of a warning
If you see a blank page, we advise you stop trying to visit the site.
If you need any help with Web Threat Protect you can chat with a Support Assistant
