If you have BTnet, you can switch on Wi-Fi and update your settings using the BTnet Wi-Fi settings form.
BTnet comes ready with Wi-Fi and Guest Wi-Fi settings to suit many customers. The table below shows the default settings, plus the available settings you can change them to.
This information will help you fill in the form and choose the right BTnet Wi-Fi and Guest Wi-Fi settings for your business.
Wireless option |
Available settings |
Default Setting |
Notes |
SSID 1 |
(and choose name) |
Disabled |
The main name for the network |
SSID 2 |
(and choose name) |
Disabled |
As above, but a separate network for your Guests to use |
Wi-Fi passwords |
n/a please specify |
User selectable |
Security encryption type |
User selectable per SSID |
Visibility of SSID |
Advertise this SSID publicly |
If you want to hide any of your active SSID’s. Can be set independently for each SSID if both are active. |
The following settings are only available for BTnet 500Mb and 1Gb circuits |
Per client bandwidth limit |
Unlimited |
If you need to set the wireless bandwidth limit for a certain connected device (client) |
Per SSID bandwidth limit |
Unlimited |
If you need to set the wireless bandwidth limit for a certain SSID, including limiting Guest Wi-Fi bandwidth |
Scheduled availability |
(with options then for):
Disabled |
If you want to make each SSID only available at certain times. ‘Disabled’ setting means SSID's are available all the time as default. |
The available configuration options are subject to change and will be updated here where applicable. Please see www.bt.com/terms for the BTnet service schedule and Terms and Conditions.
