Everyone loves free wi-fi. Now you can offer it.
Guest Wi-Fi is the fast, fuss-free way for you to give your customers free, unlimited wi-fi. It gets them online while keeping your private network safe, secure, and running smoothly.
Want to shout about it from the rooftops? Get some great free Guest Wi-Fi posters and stickers.
What’s the difference between Guest Wi-Fi and BT Wi-Fi?
Is Guest Wi-Fi secure?
How many guests can use Guest Wi-Fi?
Does Guest Wi-Fi affect my speed?
Switching on Guest Wi-Fi
It’s easy to set up you just need a BT Business Smart Hub or a BT Business Hub 5. If you’re not sure what you’ve got quickly check which hub you have.
When your BT Business Broadband is up and running, follow these easy steps to start giving your customers free unlimited wi-fi.
Switch on Guest Wi-Fi using My Account
Switch on Guest Wi-Fi using BT Business app
Switch on Guest Wi-Fi using BT Business Smart Hub Manager
Switch on Guest Wi-Fi using BT Business Hub 5 Manager
Switch off Guest Wi-Fi
Having technical problems? Try troubleshooting problems with Guest Wi-Fi.
