Working out the best location for your Complete Wi-Fi or Complete Wi-Fi Plus extender is straightforward. The quickest and easiest way is by using the BT Business app.
Not got the app? You can still set up your Wi-Fi disc or Wi-Fi Plus extender without it. Watch this short video to set up or follow the steps below it.
1. Where’s your wi-fi network weak?
If you don't already know, try walking around with your phone or a laptop to check the strength of your wi-fi signal.
2. The best spot for your Complete Wi-Fi or Complete Wi-Fi Plus Extender
The best spot is a clear space off the floor close to a power socket. Make sure the vents on the back of your Complete Wi-Fi disc or Complete Wi-Fi Plus extender are clear of obstructions.
3. Find a spot between your hub and the weak wi-fi area
Usually this is about halfway between the two devices. Plug your Wi-Fi Disc or Wi-Fi Plus Extender into a power socket and switch it on.
4. Wait for a single light to show
After a minute or two the light on your Wi-Fi Disc will stop flashing red and turn either solid blue or orange.
If you are using Complete Wi-Fi Plus the light will stop flashing Indigo and turn either solid blue or solid orange
- The light is orange
You have an ok wi-fi signal — try moving your Wi-Fi Disc or Complete Wi-Fi Plus extender closer to your Hub to make the signal even stronger.
- The light is blue
You’ve found a great location for your Wi-Fi Disc or complete Wi-Fi Plus extender
If you find your wi-fi blind spot isn't quite covered, try moving your Wi-Fi Disc or Wi-Fi Plus extender further away from your Hub. If you can't cover all your blind spots with one Wi-Fi Disc or extender you can contact us to request another.
On the rare occasion you need to place a Wi-Fi Disc/extender outside the reach of your Hub, your Wi-Fi Disc/extender can be connected to your Hub via an Ethernet cable. We advise against doing this though and suggest contacting us to request an additional Wi-Fi Disc.
If you are using Complete Wi-Fi Plus extenders you can connect one extender to another via Wi-Fi to extend the range.
