Skip to main content
Controlling the light on your Smart Hub 2 | BT Business
not-authored-help-and-support
If the light on your Hub is too bright or you only want it to be on at certain times, you can control it from the Hub light control tile on the Hub Manager.
Hub light control
Controlling the light on your Hub
Hub light: This is the master control, ON or OFF.
Brightness: Set the brightness to 100%, 50%, or 0% brightness.
Schedule: Switch on the schedule and you can set the time the light comes on and goes off. The brightness settings will also apply during these hours.
Did this help?
Additional support
