Skip to main content
BT One Phone training videos | BT Business
not-authored-help-and-support
We want to make sure you make the most of your BT One Phone solution. The training videos below will help get you started and introduce you to the many features and functions that BT One Phone has to offer - features designed around the way you work, with the aim of making your life easier.
How to register and find help and support on the BT One Phone portal
Getting started with the BT One Phone portal
How to use the BT One Phone mobile application
How to use the alert client
How to use the dial-in service menu (Voicemail)
How to set your availability and presence settings
SIP call handling
Did this help?
Additional support
