Follow these steps to set up a call divert on your mobile:
- Dial ** and enter one of the following codes:
- 21 to divert all calls
- 61 to divert calls not answered after 15 seconds
- 62 to divert calls when your phone is switched off
- 67 to divert calls when your phone is engaged
- Press the * key again
- Enter the phone number you're diverting calls to, replacing the 0 with +44
- Press the # key and then press call
How do I switch off call diverts?
To switch off individual call diverts:
- Dial ##
- Enter the code you used to turn call diversion; 21, 61, 62 or 67
- Press the # key
If you want to switch off all call diverts:
- Dial ##002#
- Press call
How do I check Call Diversion is on?
- Press *
- Press #
- Enter the code you used when you switched on call diversion (21, 61, 62 or 67)
- Press the # key again
