With eSIM devices there’s no physical SIM card instead it’s embedded in your device virtually. So instead of inserting it you download it by scanning the QR code we send you.
Which devices use an eSIM?
Most newer iPhone models, Google devices, and Samsung devices are eSIM compatible.
eSIM compatible devices are dual SIM. This means you can either use an eSIM or a traditional SIM with them.
Find out which devices are eSIM compatible:
iPhone
iPhone XS
iPhone XS Max
iPhone XR
iPhone 11
iPhone 11 Pro
iPhone 11 Pro Max
iPhone SE 2020
iPhone SE 2022
iPhone 12 mini
iPhone 12
iPhone 12 Pro
iPhone 12 Pro Max
iPhone 13 Mini
iPhone 13
iPhone 13 Pro
iPhone 13 Pro Max
iPhone 14
iPhone 14 Plus
iPhone 14 Pro
iPhone 14 Pro Max
iPhone 15
iPhone 15 Plus
iPhone 15 Pro
iPhone 15 Pro Max
iPhone 16
iPhone 16 Plus
iPhone 16 Pro
iPhone 16 Pro Max
iPhone 16e
iPhone 17
iPhone AIR
iPhone 17 Pro
iPhone 17 Pro Max
iPhone 17e
iPad
iPad (7th gen)
iPad (8th gen)
iPad 2021 (9th Gen)
iPad Mini (5th gen)
iPad Mini 2021 (6th Gen)
iPad mini 2024
iPad Air (3rd gen)
iPad Air 10.9 inch (4th Gen)
iPad Air 10.9 inch (2022)
iPad Air 11 inch
iPad Air 13 inch
iPad Pro 11 inch (1st Gen)
iPad Pro 11 inch (2nd Gen)
iPad Pro 12.9 inch (3rd Gen)
iPad Pro 12.9 inch (4th Gen)
iPad Pro 12.9 inch (5th Gen)
iPad Air 11 & 13 inch 2024 (eSIM only)
iPad Air 11 & 13 inch 2025 (eSIM only)
iPad Air 11 & 13 inch 2026 (eSIM only)
iPad Pro 11 & 13 inch 2025 (eSIM only)
Google
Google Pixel 3
Google Pixel 3a
Google Pixel 3a XL
Google Pixel 4
Google Pixel 4a
Google Pixel 4a 5G
Google Pixel 4 XL
Google Pixel 5
Google Pixel 6
Google Pixel 6 Pro
Google Pixel 6a
Google Pixel 7
Google Pixel 7 Pro
Google Pixel 7a
Google Pixel 8a
Google Pixel Fold
Google Pixel 9
Google Pixel 9 Pro
Google Pixel 9 Pro XL
Google Pixel 9 Pro Fold
Google Pixel 9a
Google Pixel 10
Google Pixel 10 Pro
Google Pixel 10 Pro XL
Google Pixel 10 Pro Fold
Google Pixel 10a
Samsung
Samsung Galaxy S20
Samsung Galaxy Note 20 5G
Samsung Galaxy S20 5G
Samsung Galaxy S20+ 5G
Samsung Galaxy S20 Ultra 5G
Samsung Galaxy Note 20 Ultra 5G
Samsung Galaxy S21 5G
Samsung Galaxy S21+ 5G
Samsung Galaxy S21 Ultra 5G
Samsung Galaxy S22
Samsung Galaxy S22+
Samsung Galaxy S22 Ultra
Samsung Galaxy Z Flip
Samsung Galaxy Z Flip2
Samsung Galaxy Z Flip3
Samsung Galaxy Z Flip4
Samsung Galaxy Z Flip5
Samsung Galaxy Z Fold2 5G
Samsung Galaxy Z Fold3 5G
Samsung Galaxy Z Fold4
Samsung Galaxy Z Fold5
Samsung Galaxy S23
Samsung Galaxy S23+
Samsung Galaxy S23 Ultra
Samsung Galaxy S23 FE
Samsung Galaxy A54
Samsung Galaxy S24
Samsung Galaxy S24+
Samsung Galaxy S24 Ultra
Samsung Galaxy S24 FE Enterprise Edition
Samsung Galaxy XCover 7
Samsung Galaxy A35 5G
Samsung Galaxy A55 5G
Samsung Galaxy S25
Samsung Galaxy S25+
Samsung Galaxy S25 Ultra
Samsung Galaxy S25 Edge
Samsung Galaxy S25 FE
Samsung Galaxy A36 5G Enterprise Edition
Samsung Galaxy A56 5G Enterprise Edition
Samsung Galaxy Tab S10 Series (S10, S10+, S10 Ultra, S10 FE, S10 FE+)
Samsung Galaxy Active5 Pro
Samsung Galaxy Z Fold 7
Samsung Galaxy Z Flip 7 Series (Flip 7, Flip 7 FE)
Samsung Galaxy S26
Samsung Galaxy S26+
Samsung Galaxy S26 Ultra
Sony
Sony Xperia 1 IV
Sony Xperia 10 IV
Sony Xperia 1 MK5
Sony Xperia 10 MK5
Nokia
Nokia X30 5G
Motorola
Motorola Razr 40
Motorola Razr Ultra 40
Motorola moto g53 5G
Motorola moto g54 5G
Motorola G35
Motorola Razr 50
Motorola Razr Ultra 50
Motorola Razr 60
Motorola Razr Ultra 60
Oppo
Oppo Find N2
TCL
TCL 50 Pro NXTPAPER 5G
HMD
HMD Fusion
Crosscall
Crosscall Stellar-X5
Crosscall Stellar-M6
Crosscall Stellar-X5s
Getting an eSIM
If you’ve not already got an eSIM device, check out the eSIM devices we offer:
Setting up an eSIM
How you set up your eSIM depends on what device you have. When you’ve received your eSIM and QR code pack choose your device manufacturer:
You need to be in the UK to set up an eSIM. If you’re currently roaming, you’ll need to wait until you’re home to set it up.
Swapping over from a physical SIM to an eSIM
To swap over from a physical SIM to an eSIM, please contact us.
Just so that you’re aware, there may be a charge to swap over.
Transferring my current line over to an eSIM
When you've set up your eSIM, to transfer your line over to your new eSIM you’ll need to contact us.
You’ll need the SIM serial number that’s on your eSIM card pack.
Switching your existing number over to an eSIM
You can switch (port) your existing number from another provider over to us. Find out how to switch your number over.
I can't scan my QR code
If you can’t scan your QR code, don’t panic, you can setup up your eSIM manually. How you do this varies from device to device:
Something wrong with my eSIM
If something’s wrong with your eSIM please contact us.
Restoring your eSIM device
Your device's user guide will tell you what to do, or you can contact us.
If you restore your device yourself, make sure you select keep your data plan and don’t erase any downloaded SIM's, otherwise you’ll delete your eSIM.
If you’ve accidentally deleted your eSIM and erased your data plan, you'll need a new eSIM. Please contact us to arrange this.
eSIM card’s default PIN number
The default PIN number for an eSIM is 1111.
