If you have a single static IP there's no need to configure your Hub, as the address is obtained automatically from the connection.
To use multiple Static IP addresses, you must have signed up for them when you ordered your BT Business Broadband service or subscribed to them through My BT Business account.
Note: Static IPv6 doesn't work on BT Business Hub 3 or earlier versions.
