Skip to main content
Using Microsoft Teams on your mobile | BT Business
not-authored-help-and-support
Your guide to Microsoft Teams Operator Connect
I need...
What do you need help with?
Get help
You can use Microsoft Teams on your mobile to make and receive business calls using Operator Connect, just like you would on desktop.
This article covers how to manage your call settings, make calls, check voicemail and transfer calls on your mobile device.
Manage call settings on your mobile
You can control how incoming and outgoing calls are handled in Microsoft Teams on your mobile.
Find out how to Manage call settings on your mobile in this YouTube video. 
How to access your call settings
  1. Open Microsoft Teams on your mobile device.
  2. Select your profile picture (top left).
  3. Select Settings, then Calling.
From here, you can:
  • set up call forwarding
  • choose Also ring (ring another device or call group at the same time)
  • decide what happens to unanswered calls
  • change your voicemail greeting
  • block calls
Settings may vary slightly depending on your device (iOS or Android) and your organisation’s setup.
Manage call queues
Opt in or out of a call queue
You may want to temporarily leave a call queue (for example, during a break or when you’re unavailable).
To turn a call queue on or off:
  2. Select your profile picture.
  3. Go to Settings, then Calling.
  4. Under Call queues, find the queue you want to manage.
  5. Use the toggle to turn it on or off.
Make a call on your mobile
You can make a Microsoft Teams call on your mobile in a few different ways.
Find out how to Make a Microsoft Teams call on your mobile in this YouTube video.
Use the Calls tab to make a call
  2. Select the Calls tab.
  3. Use the dial pad to enter a number.
  4. Select the Call button.
Or:
  2. Go to the People tab.
  3. Search for a contact.
  4. Select the Call button next to their name.
Call from your history
  3. Select History.
  4. Choose the contact you want to call.
  5. Select the Call icon under their name.
Manage voicemail on your mobile
You can use Teams to check and manage your voicemail messages.
Find out how to use voicemail on your mobile in this YouTube video.
Listen to your voicemail
  1. Open Microsoft Teams on your mobile.
  2. Select Voicemail from the navigation menu.
  3. Select the Play button on a message to listen.
  4. Select the Call icon to return the call.
Transfer a call
You can transfer an active call to someone else in your organisation.
Find out how to transfer a call on your mobile in this YouTube video.
How to transfer a call on your mobile
  1. While on a call, select More actions (three dots).
  2. Select Transfer.
  3. Search for the person you want to transfer the call to.
  4. Select their name.
  5. Select Transfer to complete the transfer.
In some cases, you may also see Consult first, which lets you speak to the person before completing the transfer.
Did this help?
Additional support
