Skip to main content
My number isn't receiving inbound calls in Operator Connect | BT Business
not-authored-help-and-support
Your guide to Microsoft Teams Operator Connect
I need...
What do you need help with?
Get help
To complete the tasks in this article, you’ll need to be an administrator. Learn more about Teams administrator permissions.
If a number isn’t receiving inbound calls, there are a few things you can check.
Suggested help
Number hasn’t ported
Your number may not have successfully moved across (ported) from your previous provider.
Solution:
  • If the port is stuck or rejected, BT may need to resubmit or correct the order. Please contact our support team.
Numbers not syncing between BT and Microsoft Teams
There may be a delay in synchronisation between BT and Microsoft Teams.
Solution:
  • Allow up to 24 hours after port completion for the number to sync.
  • Refresh Teams Admin Centre and check again under: Voice, then Phone numbers, then Operator Connect.
  • If you're still having issues, please contact our support team.
Number region doesn’t match tenant region
The number’s country/region may not match your tenant location.
Solution:
  • Check the number’s country code and region. If it’s incorrect, contact our support team to update it.
Number ported but not showing in Teams Admin Centre
The number may not yet have been allocated to your tenant by BT.
Solution:
  • Allow up to 24 hours for the number to appear in Teams Admin Centre.
  • Check the BT portal to confirm the number is visible. If it’s visible, confirm it’s assigned to the correct tenant ID by contacting our support team.
Incorrect or missing porting documentation
The port request may have been rejected because the details didn’t match your previous provider’s records.
Solution:
  • Ensure the company name, address, and account number match exactly.
  • BT may need to resubmit the port order. For further support, contact our support team.
Number ported but not assigned to a user
The number may be available in Teams but not yet assigned to a user.
Solution:
Emergency address missing or invalid
Teams will not activate a number without a valid emergency address.
Solution:
Did this help?
Additional support
