Skip to main content
Set up your Cloud Voice Express desk phone | Cisco 6861 | BT Business
not-authored-help-and-support
Help & Support Banner
Get the most out of your fibre and digital line bundle
Thanks for ordering your BT fibre and digital line bundle. It's time to set up your new service and equipment.
What do you need help with?
Set up your Cloud Voice Express desk phone (Cisco 6861)
Setting up your Cloud Voice Express desk phone is quick and easy.
Activated your service yet?
If you haven’t done so already, activate your new Cloud Voice Express service using our handy app before setting up your desk phone.
Find out how to activate your service
Important: if you’ve ordered any phones from us, only plug them in after your Cloud Voice Express service has been activated – if you plug them in too early, this may cause disruptions to your service.
Once your Cloud Voice Express service is activated, set up your desk phone
First, you'll need to check your broadband is working - your Hub’s light will be blue if it is. You’ll also need to turn on your phone and plug the handset into the port on the phone’s base.
You'll see network failure displayed on screen when you do this. Don't worry it means you're ready to get connected. There are two ways you can do this:
Using an Ethernet cable
Plug the Ethernet cable provided into the port on the base of the phone and the other end into a port on your Hub. After 30 to 60 seconds you'll be automatically connected.
Using wi-fi
There are two different ways you can connect to wi-fi. One is using your wi-fi password on the back of your hub. The other is using the WPS button on your hub.
Wi-fi password
  1. Press the settings button on your phone to bring up the menu.
  2. Select Network configuration.
  3. Select Wi-Fi configuration.
  4. Select Wi-Fi type.
  5. Select WLAN.
  6. Select Set.
  7. Select Wi-Fi Profile.
  8. Select PSK.
  9. Then, choose Scan.
  10. Now select your Hub from the list, scroll to Passphrase, enter your wi-fi password using the keypad and click Connect.
WPS button
  5. Select WPS.
  6. Select Set.
  7. Choose push button configuration.
  8. Then, tap Select.
  9. Now press the WPS button on your Business Hub, then tap continue when you’ve done this.
Your phone will automatically connect after 30-60 seconds. You’ll see your phone number on the screen and a green light on the top left button when it’s done this. If your phone hasn't connected, you'll need to repeat the steps above.
If no phone number is displayed on your desk phone
If a phone number isn't showing, then follow the instructions to set up an additional desk phone.
How to factory reset your Cisco 6861 desk phone
Sometimes your phone might not connect as the firmware isn’t installing properly. In this case you’ll need to do a factory reset to reinstall the firmware:
  1. Connect your phone as outlined in the steps above.
  2. Press the Settings button on your phone.
  3. Select Device Administration.
  4. Select Factory reset.
  5. Press Select - you’ll be asked “Do you want to perform a factory reset”.
  6. Select OK.
  7. Your device will reboot and display the Cisco logo, and then “Network configuration failure”.
  8. Now, re-connect your Cisco 6861 following the steps outlined above.
You can also download the Cisco 6861 desk phone user guide (PDF, 2.1MB) for more help.
Did this help?
Additional support
