Skip to main content
How to set up your BT Business Smart Hub 2 (Fibre Basic) | BT Business
not-authored-help-and-support
How do I set up my BT Business Smart Hub 2 (Fibre Basic)?
It’s easy to get everything up and running, just follow the step-by-step instructions.
Engineer visit
If you’ve got an engineer coming to set-up your broadband, it’s even easier and you can sit back and relax. Just have your Hub ready for when they arrive.
If you’ve ordered a Hybrid Connect device then you can get connected and online straight away without waiting for your broadband being activated. Just plug in your hub and add your device as shown on the packaging or read the setting up Hybrid Connect page.
How to install it yourself:
1. Remove your old hub
If you have one, switch off and unplug your existing hub before installing your new Business Smart Hub 2.
Remove your old Smart Hub
2. Check your phone socket
Use the master phone socket to make sure you get the best broadband connection.
Double master socket and single master socket
3. Plug your hub into your phone socket
Plug one end of your broadband cable (the one with the grey ends) into your new hub and the other into the master socket or filter (if you're using one).
Plug hub into master socket
  • Use the broadband cable with grey ends.
  • Only use the plug that comes with your hub.
4. Switch on your Hub
Using the power button on the back of the hub, switch it on.
Switch on your Smart Hub
5. Wait for a solid blue light
When you see this, your hub is ready. It can take a few minutes, so why not make yourself a cuppa in the meantime?
Wait for a solid blue light on Smart Hub
6. Scan the QR code
Scan the square code on the back of your hub to automatically enter your network and admin passwords, or, do it manually if you prefer.
Scan the QR code on the back of your Smart Hub
That’s it, you’re all done, you’ve set up your BT Business Broadband and Smart Hub 2.
If you've got Hybrid Connect you'll need to set it up:
Set up Hybrid Connect
Setting up Hybrid Connect is straightforward. You’ll need to do this to get the best performance from Hybrid Backup and Hybrid Speed Boost.
Need help setting up something else? Head over to getting started with your BT Business products.
Did this help?
Additional support
