To register an existing, new or replacement IP phone - including a phone with a new MAC address:
- Plug the IP phone into the socket.
- Let the phone boot up and you'll eventually see a message saying either:
- Use Super Key to send the PIN.
- Use Hold Key to send the PIN.
- Dial ### or ***
### is to register replacement phones.
*** is to register new phones for 1st time registration. - Dial the extension number.
- Press the Super Key or Hold Key depending on what is on the phone display.
- Your phone should now register with the system.
If the phone fails to register, then check your Mitel DHCP setting is enabled.
Registering a Mitel 5302 phone
- Log on to the Mitel MCD. If you need help, find out how to connect to your MN3300 system.
- At the top left of the screen select View Alphabetically from the dropdown.
- Click the Users and Devices Configuration form and create an Extension Account.
- Plug the phone in to the socket.
- Let the phone power up.
- Leave the Handset off the hook and to the side of the phone.
- Hold the * key down until all three lights are flashing (they will start flashing individually, then all three solid and finally all three flashing). Then release the * key.
- Now press the # key.
- Enter the extension number.
- Press the # key.
- Press the * key three times.
- Press the # key.
- The lights should go out. It will take a few minutes for the dial tone to come through.
- Then replace the handset.
