Skip to main content
How do I change the time on my MN3300 system? | BT Business
not-authored-help-and-support
Changing the time on the MN3300 system
To change the time on the MN3300 system:
  1. Log in to your Mitel MN3300 programming.
    If you don't know how to do this go to How do I connect to my MN3300 system? for more help.
  2. Click Group Administration Tool.
  3. Click Change Date and Time. Enter the correct date/time.
  4. Click OK.
  5. Click OK to continue.
Did this help?
Additional support
