Differences between call forwarding & call rerouting on MN3300
Call Forwarding is programmed & activated at the telephone. Call Rerouting is programmed in the system database using ESM programming forms.
If someone call forwards their phone to another answer point, the forwarding they programme overrides the equivalent rerouting programmed in the system database for their phone.
Precedence:
- Call Forward - Always
- Call Reroute - Always
- Call Forward - Busy/No Answer
- Call Reroute - Busy/No Answer
Setting up system call forward on MN3300
You can set up system call forward from your extension to a mobile or landline by following the steps below.
The best way is to always forward to the same number, that way it can be set up as a Speed Call.
Set up Speed Call:
- Login to your Mitel system.
- From the homepage navigate to the System Property - System Feature Settings - System Speed Call form.
- Click Add.
- When the window opens enter the new Speed Call details:
- Speed Call Number - XXX or XXXX (make the number of digits the same as your Extn digit length)
- Enter the actual number - (9) or the access code for an outgoing line on your system followed by mobile or landline number e.g. (9) 0778XXXXXXX or (9)011324XXXXX (9 then the full number)
- Override T/C - Yes
- Select S/C option
Speed Call - 450 Act No - 9078xxxxxx Override - Yes Select S/c
This saves having to then change the COS for the phones and trunks with Override to Yes.
Set up a Call Forward Profile:
- Go to the User & devices - Advance Configuration - Call Forward Profile form.
- Click Add.
- When the window opens enter the new Call Forward details:
- Number - xxx or xxxx (the extension that wants the calls forwarding)
- Type - Always
- Fwd Dest - 450 (put in the speed call number you assigned in 4 above)
- Turn on if testing
Program a button on the phone:
- Go to the User and Devices - User and Devices Configuration form.
- Highlight the extension that wants to Call Forward.
- Click Change.
- Once the extension page has loaded, click the Key tab.
- Highlight an unassigned key or a key that's not needed and click Change Key.
- When the window opens enter the new Key details:
Label - write a label you'll understand (this will only show on phones with a screen)
Line Type - Call forward Always
Make sure it's the correct call forward type as selected above in Setting up a Call Forward Profile. - Click Save.
- When complete, turn on Call Forward (the key should light up) and test.
How to set up or cancel call forward on your MN3300 extension
Set up call forward on your MN3300 extension
To set up call forward on your MN3300 extension:
- Press the blue Super Key or the programmed Super Key screen button.
The 5320, 5330, 5340, and 5360 will need the Super Key to be programmed as a screen button, please see How do I Program my buttons? - You should see the first option, Phonebook.
- Select No, until you see Call Forwarding, select Forwarding.
- Select Review.
- Select Change key.
- Select Program and enter the number.
- Select Save/Off.
- Select Turn Fwd On - you should see a Call Fwd symbol in the top left corner of the screen on some phones.
- Press Cancel until you're to your home screen. Call forward should now be set up.
To cancel call forward:
To turn call forward off:
- Select Review.
- Select Save/Off.
- Press Cancel until you're to your home screen. Call forward should now be switched off.
