If you struggle to hear or speak on the phone, The Relay UK app can really help.
If you have difficulty hearing on the phone, a Relay Assistant will type what the other person is saying, so that you can read their words in real time.
If you have difficulty speaking on the phone, a Relay Assistant will speak the words you type, so the other person can hear your words in real time.
The free Relay UK app works with ordinary smartphones, tablets, laptops and PCs which means you can use the relay service wherever you can get an internet connection. You can also still use a textphone as you could with the old text relay service.
Find out more on the Relay UK website.
