Call Waiting tells you when other callers are trying to get through. You will hear a discreet beep when someone is waiting to connect while you're on the phone. You can choose whether or not to take the call.
To switch on:
- Press * key.
- Enter 43.
- Press # key.
To speak to caller waiting to connect:
- Wait for beep.
- Press Recall.
To return to initial caller/called party:
- Press Recall.
- When you've finished, simply hang up.
To check it's on:
- Press # while holding down *.
- Press 43.
- Press #.
To switch off:
- Press #.
- Press 43.
- Press #.
Note:
Call Waiting is not compatible with Internet Call Waiting.
Further information
For information on the complete range of calling features, please view the
Calling Features user guide (PDF 91KB)
Note: You may need Adobe Reader to view PDF documents.
