Skip to main content
I'm having problems with BT Text | BT Business
not-authored-help-and-support
You can check BT Text is working correctly by texting 'reset' to 00000. The system will identify this inbound message as a text and send an acknowledgement text to your handset.
This can also be used to reset the system if you are having problems with incoming text messages being delivered as Voice Text TTS.
If you are not receiving your messages as a text, check Caller Display has been activated:
  • To check if this is Activated * # 234 # .
  • To activate Caller Display * 234 #.
If you are still experiencing difficulties with BT Text, please report a fault online or ring the helpdesk. Click on the 'Contact us' link on this page for their contact details.
Did this help?
Additional support
