Skip to main content
I'm having problems with SIP and calls are cutting off after 15 minutes
not-authored-help-and-support
If you're having problems with SIP and calls are cutting off after 15 minutes, it could be a problem with firewall configuration.
To fix it, check the following:
  • Consistent NAT (Network Address Translation) is enabled.
  • Single Sign On Authentication Packet is turned off or disabled.
  • NAT Refresh Timer is greater than 120 seconds - it may also be called NAT Timeout or UDP Inactivity Timer.
  • SIP ALG is disabled - it may also be called SIP Transformation.
If this doesn't work, then contact us.
Did this help?
Additional support
