Skip to main content
How do I handle live calls on my BT One Phone? | BT Business
not-authored-help-and-support
You have the following call handling options when using your BT One Phone device, but only if you're in the UK:
Placing a call on hold
Transferring a call (with or without talking to the person you're transferring to first)
Switching between two active calls
Setting up a three-way conversation
Call waiting
Ring back when free
Did this help?
Additional support
