Skip to main content
A guide to Business Antivirus Detect and Respond | BT Business
not-authored-help-and-support
A guide to BT Business Antivirus Detect and Respond
What is BT Business Antivirus Detect and Respond?
BT Business Antivirus Detect and Respond is a cutting-edge Endpoint Detection and Response solution designed specifically for small and medium-sized businesses. Powered by CrowdStrike Falcon Go, and enhanced by BT's renowned service excellence, this product offers robust protection with its Next Generation Antivirus (NGAV) technology.
Business Antivirus Detect and Respond proactively quarantines malicious files, blocks suspicious processes, and contains endpoints at the network level, ensuring your business stays secure against evolving cyber threats.
Key features include:
  • Next Generation Antivirus.
  • Endpoint Control and Response.
  • A simple user interface (UI).
  • USB Device Control.
  • Easy setup.
How to activate BT Business Antivirus Detect and Respond
If you’re accessing it for the first time
Once you’ve purchased Business Antivirus Detect and Respond, you’ll be sent an email on how to log in for the first time and activate your account. Click the ‘Activate My Falcon Account’ link.
Screenshot of CrowdStrike email to activate Falcon Account.
      1. You’ll be asked to set a secure password for your account.
Screenshot of setting password.
      2. Next, you’ll be prompted to set up 2 Factor Authentication (2FA). You will need an app that supports time-based one-time passcodes to complete this step. Follow the steps on screen to finish setting up 2 Factor Authentication.
Screenshot of passcode prompt for 2 Factor Authentication.
      3. When you log in for the first time, you’ll be greeted with a welcome wizard that contains several informative videos to help you familiarise yourself with the user interface.
Screenshot of welcome to CrowdStrike screen.
      4. Once you’ve completed all the steps in the welcome wizard, you’ll be able to start using your new product.
Screenshot of Falcon dashboard.
After the initial setup, you’ll be able to access your product through BT Business Apps marketplace.
Accessing Business Antivirus Detect and Respond after initial set up
To access Business Antivirus Detect and Respond going forward, you’ll need to use your BT My Account details to log in to BT Business Apps.
  1. Once you’ve logged in to BT Business Apps, go to your My Apps tab.
Screenshot of My Apps tab.
      2. Select the Business Antivirus Detect and Respond tile.
      3. You’ll be taken to the Crowdstrike webpage and be prompted to log in to Crowdstrike.
Screenshot of credentials added to CrowdStrike.
      4. Then, log in with your Crowdstrike credentials – these will have been provided to you on the email we sent you.
You’ll now be able to manage your service.
Frequently asked questions (FAQs)
How do I deploy a sensor?
For Windows:
Alternatively, CrowdStrike provides a written tutorial that covers both manual and automatic Windows installations.
For MacOS:
Alternatively, CrowdStrike provides a written tutorial that covers both manual and automatic MacOS installations.
Why am I getting an 'installation failed' screen, when installing a sensor?
For Windows:
Windows installation failed message
For MacOS:
Mac OS installation failed message
This means you've used all your licences. You won't be able to deploy any more sensors until you delete an old device, or purchase more licences.
To buy more licences, contact your Sales team or log in to your BT Business apps account to purchase.
Where can I learn more about using Business Antivirus Detect and Respond?
You can find user guides and technical documentation in the Business Antivirus Detect and Respond Portal. Log in to Crowdstrike and you’ll be taken to the support content.
Are there any minimum system requirements?
  • All supported sensor versions for Windows, Mac, and Linux on workstations.
  • All supported sensor versions for Android 9.0 and later and iOS 15 and later mobile devices.
How can I purchase Business Antivirus Detect and Respond?
  • If you’re a new customer, please get in touch with our sales team via our contact page.
  • If you’re an existing customer, you can contact your sales team or order online following these simple steps:
  1. First, log into My Account.
    Not registered with My Account? Create an account.
Screenshot of BT Business Apps selected on the dashboard.
      2. From the Dashboard, go to Products and Services and click on BT Business apps.
Screenshot of BT My Account.
      3. The BT Business apps marketplace, will launch.
Screenshot of Business Apps on Marketplace.
      4. Click Security from the categories on the left-hand side.
      5. Then, in Featured Applications, select Business Antivirus Detect and Respond.
Screenshot of Business Antivirus Detect and Respond application.
      6. Click Buy Now in the top right corner, and follow the on-screen steps to purchase the product.
Screenshot to purchase Business Antivirus Detect and Respond.
      7. Once you’ve purchased Business Antivirus Detect and Respond, you’ll receive an email which will contain instructions to set up your new product.
Troubleshooting Business Antivirus Detect and Respond
If you experience any issues or faults with the service and need to contact our service team, please log into faults and repairs and follow the on-screen instructions. You’ll need to log in with your BT My Account username and password.
If you’ve forgotten your BT My Account user name or password, find help at I've forgotten my username or password. What should I do?
Did this help?
Additional support
