You should have received your unlocking code via text. Please follow the steps below to unlock your Samsung device.
Important
Please only try this process once. If you have any problems, contact us.
To unlock your device, please follow these steps:
1. Insert a non-BT SIM card
2. Switch on the device
3. The device will display 'Network lock', 'Wrong card' or 'Invalid card'
4. Enter #0111* <<your unlocking code>> #
5. Press OK
6. The device will display 'Personalisation optimised'
Your device should now be unlocked.
