Skip to main content
Completing the unlock process on your Samsung | BT Business
not-authored-help-and-support
You should have received your unlocking code via text. Please follow the steps below to unlock your Samsung device.
Important
Please only try this process once. If you have any problems, contact us.
To unlock your device, please follow these steps:
  1. Insert a non-BT SIM card
  2. Switch on the device
  3. The device will display 'network lock' or 'enter password'
  4. Enter your unlocking code
  5. Press OK
Your device should now be unlocked.
Did this help?
Additional support
