If you need to add or remove an extension user from a hunt group using the IP Office Manager, follow these simple steps:
Adding an Extension user to a Hunt Group
- Log into IP Office Manager.
- Click and expand Hunt Group.
- Click on the Hunt group to be changed.
- The User List will show all the extension users assigned to this hunt group.
- Select Edit.
- Select the Extension Users you want to assign to the hunt group and select Append.
- The extension users are now assigned. You can assign more extension users if required or select OK.
- Select OK again and send the updated configuration to the IP Office by selecting Merge.
Removing an Extension user from a Hunt Group
- Select the Extension User you want to remove.
- Select Remove.
- Select OK to save the changes and send the updated configuration to the IP Office by selecting Merge.
