Skip to main content
What BT Mobile products and services are available? | BT Business
not-authored-help-and-support
We're all about keeping you communicating and we've a wide range of products and services available to help you stay connected.
BT Wi-Fi Hotspots
With over 5 million BT Wi-Fi hotspots available across the UK in public locations, we're providing wireless internet access where it's needed most like airports, hotels and motorway service stations.
Find out more about using available BT Wi-fi hotspots across the UK
Keeping connected on the London Underground
We're providing Wi-Fi access at over 150 stations on the London Underground in partnership with Virgin Media. Ticket halls, walkways and platforms are all covered, but it's not available in tunnels or between stations. Check which stations are connected
If you're an active BT mobile customer, access is included as part of your mobile contract with BT, meaning no extra charges.
Stay secure with Mobile Iron by BT
Mobile Iron is a mobile device management (MDM) solution designed to protect your business information. It manages content, settings and security across mobile devices.
Learn more about Mobile Iron device management
What's BT Mobile Manager?
This is a free digital service we offer to help you manage your account. You can use it to keep track of your phone usage and spending.
Find out more and register for BT Mobile Manager
What is Visual Voicemail?
This is a network feature only available to iPhones. You can use it to see a list of your messages and choose which ones to listen to or delete.
To activate it text iPhone visual on to 150 , to stop text iPhone visual off to 150 .
What does it cost?
Visual Voicemail needs access to data so any data used to access it is charged according to your tariff. If you've used up your data allowance, you'll be charged for any data usage.
Does Visual Voicemail work when I'm abroad?
Yes, it does. However, as it uses data, we recommend that you turn the service off whilst roaming to avoid any additional roaming costs.
Did this help?
Additional support
