Computers use IP addresses to locate and talk to each other on the internet in the same way people use phone numbers to locate and talk to one another on the phone network.
There are two types of IP addresses: A dynamic IP address and a static IP address.
When you connect to the internet you are assigned an IP address and this is usually provided dynamically. If you have a dynamic IP address, when you disconnect from the internet, the IP address goes back into the IP address pool so it can be assigned to another user. This means that when you connect again you will probably get a different IP address.
A dynamic IP address is not suitable if you want a computer to be permanently visible on the internet. For your IP address location to be visible at all times, you should use a Static IP address.
Tip: If this article didn't answer your question, please see if a similar question has already been answered in the BT Business Community. If not, please post your question; other customers may be able to help.
