Your BT Business Hub will allow you to broadcast your very own BT/EE Wi-Fi hotspot. This can be done through the BT Business Hub's web interface.
The Hub Manager is where you can change or view your Hub's settings
- Open your web browser: Type 192.168.1.254 into the address bar (where you normally type the internet address; there's no need for www or http, just type the number directly into the address bar) and press 'Enter'.
- Select Public wi-fi.
- When you’re prompted, enter your Hub admin password and click OK. This password can be found on the setting’s card on the back of your hub.
- You can toggle BT/EE Wi-Fi ON or OFF.
The status shows as pending until this process has completed and can take up to 24 hours.
