All you need to know about setting up and managing your BT Business Hub 3.
Not sure if this is your hub or router? Check which BT Business Hub or router you’re using.
Setting up
How to connect your BT Business Hub 3.
Connecting a USB Drive to the USB socket.
Changing the wireless or SSID settings.
Creating a wireless connection using WPS.
Managing
Setting up MAC address filtering.
Changing the wireless channel.
Removing inactive computers from the BT Business Hub 3.
Changing the broadband network connection password.
Entering the broadband network username and password.
