Skip to main content
Home
Login / Register
Using the BT Business Smart Hub | BT Business
not-authored-help-and-support
Business help
Guide to using the BT Business Smart Hub
Find our tips to get the most from your Smart Hub, from setting it up to fixing problems.
What do you need help with?
Getting started
Using
Troubleshooting
What do you want help with?
Changing the IP address of your hub
How do I change my Smart Hub’s wireless settings?
How do I view the devices connected to my Smart Hub?
How do I restrict the wireless devices that can connect to my Hub?
How do I assign multiple Static IP addresses on the Smart Hub?
How do I use my Smart Hub as a modem only?
How do I use different DNS servers or set up dynamic DNS on my Smart Hub?
How do I control the time when devices can access the internet on my Smart Hub?
Controlling the light on your Hub
How do I create a Port Forwarding rule on my Smart Hub?
What is MultiNAT and how do I set it up?
Where can I view the status of my Smart Hub?
Additional support
Live Chat
The quickest and easiest way to contact us.
Chat now
Contact us
Online, Chat, WhatsApp.
Find contact options
Back to top
