Skip to main content
Home
Login / Register
Using the BT Business Smart Hub 3 | BT Business
not-authored-help-and-support
Business help
Your BT Business Smart Hub 3 guide
Find our tips to get the most from your BT Business Smart Hub 3, from setting it up to fixing problems, you’re in the right place.
What do you need help with?
Getting started
Using
Troubleshooting
What do you want help with?
Using Smart Hub 3 as a modem only
Changing the wireless settings on Smart Hub 3
Setting up IPv4/IPv6 DNS servers or dynamic DNS on Smart Hub 3
Changing the IP address of your Smart Hub 3
Set up and assign multiple Static IP addresses on the Smart Hub 3
Creating a Port Forwarding rule on Smart Hub 3
Control the time when devices can access the internet on Smart Hub 3
View the status of your Smart Hub 3
Restricting the wireless devices that can connect to your Smart Hub 3
Controlling the light on your Smart Hub 3
Wi-fi Security Controls - Frequently Asked Questions
How to activate Wi-fi Security Controls
Wi-fi Security Controls: features and settings
Using a VPN with your BT Business Smart Hub 3
Additional support
Live Chat
The quickest and easiest way to contact us.
Chat now
Contact us
Online, Chat, WhatsApp.
Find contact options
Back to top
