Skip to main content
Issues porting phone number to Operator Connect | BT Business
not-authored-help-and-support
Your guide to Microsoft Teams Operator Connect
I need...
What do you need help with?
Get help
To complete the tasks in this article, you’ll need to be an administrator. Learn more about Teams administrator permissions.
If a number hasn't successfully moved across (ported), check these possible causes:
Suggested help
Port request hasn’t completed
The port order is still pending or hasn’t been fully processed.
Solution:
  • Confirm with BT that the port order has been marked as completed (please allow 24 hours for sync).
  • If the port is stuck, BT may need to re-submit or correct the order. In this case, please contact our support team.
Numbers not syncing between BT and Microsoft Teams
There is a delay in synchronisation between the operator and Microsoft Teams.
Solution:
  • Allow up to 24 hours after port completion for sync.
  • If the number appears in the BT portal but not in Teams, request a resync from BT.
  • Refresh Teams Admin Centre and check again under: Voice, then Phone numbers, then Operator Connect.
Number region doesn’t match tenant region
The number’s country/region doesn’t match your tenant location.
Solution:
  • Verify the number’s country code.
  • If the number data is incorrect, contact our support team to correct it.
Number ported but not showing in Teams Admin Centre
The number has not yet been allocated to your tenant by BT.
Solution:
  • Check the BT portal to confirm the number is visible. If it is, confirm it is assigned to the correct tenant ID, by contacting our support team.
  • Refresh Teams Admin Centre after 30–60 minutes.
Incorrect or missing porting documentation
The port request was rejected because the information didn’t match your previous provider’s records.
Solution:
  • Ensure company name, address, and account number match perfectly.
  • BT may need to re-submit the port order. Please contact our support team for further help with this.
Number ported but not assigned to a user
The number is in Teams but has not been assigned to a user.
Solution:
Confirm the number is in the Operator Connect inventory in Voice, then Phone numbers, then Operator Connect. Then assign the number to a user. If the number is not appearing in Teams, please contact our support team.
Emergency address missing or invalid
Teams will not activate a number without a valid emergency address.
Solution:
Did this help?
Additional support
