Skip to main content
Common FAQS for Operator Connect | BT Business
not-authored-help-and-support
Your guide to Microsoft Teams Operator Connect
I need...
What do you need help with?
Get help
Get help with common issues with Operator Connect
Suggested help
Newly provisioned numbers are not appearing in the Teams Admin Centre
Solution: Confirm the operator has completed provisioning and that the tenant is licensed correctly.
  • Check with your operator that the numbers have been assigned to your tenant.
  • Allow time for Microsoft sync (usually within minutes, but can take up to 24 hours).
  • Verify you have available Teams Phone licences.
  • Refresh Teams Admin Centre > Voice > Phone numbers.
Unable to assign a phone number to a user
Solution: Ensure the user has the correct licence and usage location.
  • Go to Microsoft 365 Admin Centre > Users > Active users.
  • Select the user.
  • Under Licences and apps, confirm Teams Phone is assigned.
  • Under Settings, verify the Usage location matches the number’s country.
  • Go to Teams Admin Centre > Users > Manage users and try assigning the number again.
Users cannot make or receive calls
Solution: Check licensing, number assignment, and Teams client registration.
Steps:
  • Confirm the user has a Teams Phone licence.
  • Verify the phone number is assigned under Users > Manage users > Account.
  • Ask the user to sign out and back into Teams.
  • Check for conflicting call forwarding rules under Voice > Call answering rules.
Auto attendant or call queue is not receiving calls
Solution: Ensure the resource account is licensed and the number is assigned correctly.
  • Search for the resource account.
  • Confirm Phone System – Virtual User licence is assigned.
  • Go to Teams Admin Centre > Voice > Phone numbers.
  • Search for the number and verify it is assigned to the correct resource account.
  • Review the Auto Attendant or Call Queue configuration under Voice > Auto attendants / Call queues.
Calls are routing to the wrong user or service
Solution: Check number assignment and call routing rules.
  • Search for the number.
  • Check the Assigned to field.
  • Reassign the number if incorrect.
  • Review user call forwarding settings under Users > Manage users > Voice.
Ported numbers are not working after migration
Solution: Verify port completion and number status.
  • Search for the ported number.
  • Check the Status (should show Assigned or Available).
  • If the number shows Pending, Unassigned, or Unavailable, contact your operator.
  • Reassign the number to the correct user or resource account if needed.
Emergency address is incorrect or not updating
Solution: Update the emergency location and confirm usage location.
  • Edit the Emergency location.
  • Confirm the user’s Usage location matches the number’s region
Users are receiving calls on the wrong device
Solution: Review call forwarding and simultaneous ring settings.
  • Go to Teams Admin Centre > Users > Manage users.
  • Select the user.
  • Under Voice, check Call forwarding.
  • Ask the user to check their Teams client for:
    • Simultaneous ring
    • Forwarding rules
    • Multiple device sign ins
Operator Connect numbers are missing or unavailable
Solution: Confirm provisioning and tenant assignment with the operator.
  • Contact your operator to confirm:
    • Numbers are provisioned
    • Numbers are assigned to your tenant
  • Check for any filters hiding the numbers (e.g., country, status).
Resource account calls are failing
Solution: Ensure the resource account is fully configured.
  • Confirm Phone System – Virtual User licence is applied.
  • Verify the number is assigned to the resource account.
  • Check the associated Auto Attendant or Call Queue configuration.
Did this help?
Additional support
